1989 Buick Century INJECTORS NT COMMING ON
1989 BUICK CENTURY
150,000 MILES • 6 CYL • 2WD • AUTOMATIC
THEAARON80
THIS CAR WONT START....I PUT NOID LIGHTS ON THE INJECTORS AND THEY ARE COMMING ON BUT THE LIGHT IS REAL DIM BUT THEY ARE NTO FLASHING. I DID PUT 3 COMPUTERS IN THE CAR AND ALL 3 DID NTO CHANGE PROBLEM. (2 AFTERMARKET COMPUTER AND 1 USED). I HAVE ALSO CHECK ALL THE WIRING. IM STUCK.
Aug 30, 2009 at 8:25 AM
JDL
  • 16,098 POSTS
Check the actual injector voltage, should go hot with key on. Ohms test all the injectors. Any codes? If there is a problem causing the computer to go bad, you need to fix that first.
Aug 30, 2009 at 9:21 AM
