With a 7mm nut driver, remove the kick panel and the cover over the map light and rear window defogger switch (screw is at bottom). Pop out the cover. Remove the instrument cluster bezel cover with phillips screws. Unbolt the radio and pull it straight out. Wiring pigtail and antenna lead are in the back.
Sep 23, 2010 at 2:15 PM
