1989 Buick Century brake light
1989 BUICK CENTURY
LINCOLN22
Brakes problem
1989 Buick Century 6 cyl Two Wheel Drive Automatic
What should I check when my brake light keeps going on and off? I mean the brake light on the dash that tells you there is a problem. Thank you for your time.
Aug 19, 2008 at 7:23 PM
MASTERTECHTIM
  • 4,750 POSTS
check the fluid level in the master cylinder, your probably a little low and the float switch is turning on the light. top off the level with dot #3 brake fluid
Aug 19, 2008 at 7:43 PM
