1976 Buick Century will not idle when engine is warm.
1976 BUICK CENTURY
85,000 MILES • 6 CYL • 2WD • AUTOMATIC
JEFFPARROTT
My car will idle and run fine as long as the choke is engaged. when the engine warms up it will not idle. As soon as the accelerator is let off the engine dies. The car runs fine as long as you are accelerating. All the hoses are good, I have added new gas, and used a whole can of carburator cleaner to loosen the varnish. The mechanic said it would require a new or rebuilt carburator which for this car is difficult to find. He checked the EGR valve and found it is functioning properly.
Jan 17, 2008 at 2:15 PM
Double check the choke initial opening and the fast idle cam adjustment. Also check the fuel filter
Jan 18, 2008 at 2:30 AM
