having an issue at approximately 3500 rpm under acceleration where the car will buck and flash the CEL however record no code. if held at this approximate rpm the tachometer will bounce between 3500 and 6000 rpm. I have had the spark plugs, coil packs, injectors and fuel pump all replaced with no avail. The shop seems to think it is the camshaft position sensor, is this the case?
Mar 22, 2016 at 10:28 AM
