Bucking, and sputtering
1993 JEEP CHEROKEE
170,500 MILES • 4.0L • 6 CYL • 4WD • MANUAL
XJBASKETCASE13
  • 8 POSTS
I have the vehicle listed above (xj model) when I take off it bucks and acts like it’s about to run out of gas! I have a dtc 24 but that tells me it’s the throttle position sensor, and I have already changed it. I replaced it with a Mopar TPS I’m lost and confused at this point.
Jan 20, 2020 at 3:25 PM
This code is telling you that your voltage is not as expected. This could be as a result of the sensor but it is more likely a wiring issue.
I attached the testing for this code but I suspect there is either a connection issue or a larger wiring issue.
Let me know if you have questions but following this test through should lead you to the issue.
Jan 20, 2020 at 7:05 PM
XJBASKETCASE13
  • 8 POSTS
Can this damage my throttle position sensor?
Jan 20, 2020 at 7:36 PM
CJ MEDEVAC
  • 11,004 POSTS
Ever change the fuel filter?
Checked the fuel pressure?
People get too wound up in these new fangled sensor infested, over engineered rigs. Anymore, you seldom hear about mechanical issues as it all seems to be masked with computer items.
Wow! You don't reckon it could be an old school symptom and it actually is starving for fuel and the cyber matrix got sidestepped by old technology? The new stuff still requires scheduled maintenance as the old stuff does.
Here's two links that might aid you from our "Repair Guides", found at the top right of our pages:
https://www.2carpros.com/articles/how-to-change-a-fuel-filter
and the other:
Keep us posted with progress.
The Medic
Jan 21, 2020 at 4:47 PM
XJBASKETCASE13
  • 8 POSTS
Seems to be a wiring issue between the TPS and the PCM. Thanks for the help though!
Jan 21, 2020 at 5:51 PM
You are welcome. Also, the only way a wiring issue can "hurt" the TPS is if it is shorting out the sensor. However, the testing would reveal this.
Glad you were able to figure it out. Let us know if you have other questions. Thanks
Jan 21, 2020 at 7:02 PM
