Truck shut off while driving, timing chain broke
2012 GMC SIERRA
98,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
NICKOLA1
Truck shut off while driving. Mechanic said the timing chain snapped. Is this engine an interference or non interference engine? Trying to decide if it's worth fixing. Could there be other damage from when it snapped?
Jan 8, 2019 at 9:44 AM
Good morning,
Although it does not show to be an interference engine, the engine running when it failed could cause damage to the valve train.
I would set the new chain and gears on and then before going anywhere else, do a compression test to verify no valve damage.
Jan 8, 2019 at 9:56 AM
NICKOLA1
Do you know if it's an interference or non interference? I can't find anything online and the dealership doesn't know. I plan on getting rid of it soon, don't want to get into big money if there's more damage.
Jan 8, 2019 at 10:06 AM
As I stated in my original post, it is not an interference engine. However, under certain conditions such as engine running under power, it can do valve damage at the time it breaks.
Jan 8, 2019 at 10:37 AM
NICKOLA1
Thanks, I didn't see the first part of your post.
Jan 8, 2019 at 10:39 AM
You are welcome.
No worries.
Always glad to help.
Jan 8, 2019 at 10:41 AM
