I was given this car LX model from my grandma. i have put some money into it but now there is some kind of electrical issue. Some fuses blew and we eventually found out that one of the relays did not look like it was in all the way. So once we looked closer we realized that whoever had the car before had the same relay go out but when they tried taking the bad one out they broke off one of the prongs in the fuse box but instead of getting it out before putting a new one in they just shoved a new one in there with the old prong still stuck in there. We have no idea how long it has been like this. we can tell it has been awhile because now the prong is corroded to the fuse box and just breaks into pieces when you try to pull it out. We also noticed the bolt that is supposed to be screwed in to the fuse box where the relay goes is missing and from what i understand it is supposed to be the ground for the fuse box and relay so it gets the proper connection, but i have no idea what kind it would need. So can anyone tell me how i can get the prong removed from the fuse box and if possible what kind and size bolt i would need please?
Feb 3, 2019 at 8:53 AM
