broken pin
2003 KIA SEDONA
160,000 MILES • V6 • FWD • AUTOMATIC
DAZEDNCONFUSED3514
Sheer pin broken off inside crank shaft from serpentine pulley (pulley is dangling). Brother in law tried using a back out tool which also broke off inside. What can I do?
May 10, 2017 at 2:42 PM
HMAC300
  • 48,601 POSTS
see if you can get a puller behind the pulley and pull it off you will probably need a new pulley. Put a bolt of comparable size in crank so you don't ruin that using a puller.
May 10, 2017 at 3:38 PM
