Broken hood latch cable
2012 NISSAN ALTIMA
120 MILES • 2.5L • 4 CYL • 4WD • AUTOMATIC
MIKEF540
I have had a recent problem arise with my AC clutch not engaging, so I went to pop my hood yesterday only to not have it pop open after pulling the lever inside the car, now there is slack in the latch cable inside the car , and will not retract with the lever it is usually attached to.
I have tried unhooking the cable from the lever in my car, pulling on the cable with vice grips, only to pull the cable inside the car about 3 more inches with no luck getting the hood to release, now the cable will not move at all.
- Not able to remove the front grill on my vehicle without the hood open to remove top clips
- not able to get any kind of tool in from the bottom with the plastic shroud off underneath my bumper
- not able to locate or access the primary release from in between the grill louvers with long flat head.
Basically I am beginning to feel like I am at a complete loss unless I take it to the dealer which I really don’t want to do, they quoted around $250.00 plus the cable cost.
I know if I can get the hood released than I will have no problem running the wire myself.
Any help would be very appreciated and thanks in advance
Jul 9, 2019 at 4:52 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Yes, You're in a tough spot.. Same thing as having door handles break and can't open door to access door panel to gain entry to handle linkage. I would suggest to have another person help you by hand pounding the hood latch area while you are using the vice grips to pull the cable.Hope this helps and thanks for using 2CarPros.
Danny-
Jul 9, 2019 at 6:47 PM
MIKEF540
I already read the above response to another question that somebody else had asked similar to mine. I do not find this very helpful at all. I just want to let everybody know that I did get it open without the help of this website, I took my inner fender on the driver side off, I located the cable going to the latch and I fished it through to my headlight so it was sticking out of the bumper area, and I was able to pull it very hard and unlatch the hood from there.
Jul 10, 2019 at 7:17 PM
If you have the cable pinch it hard with a set of vise grips and pull! let me know
Jul 11, 2019 at 4:24 PM
