So I read your article about fixing a door that will not close. In the article the latch is closed so the fix is to use a screwdriver to open the latch. I have had this problem which is an easy fix. But, what do you do when the latch is open and the door will not close because the latch will not stay closed? I used a screwdriver to close the latch and it just opens right back up without any resistance. I tried locking the door while holding the latch closed and still it opened. Please help.
Feb 1, 2017 at 12:01 PM
