I'm Swedish and my car is in Spain, This does not ease things. The mechanic doesn't speak English. He told me that the crank broke and he needs to change it. The problem is also that he needs to change all the parts that the crank is attached to. Do you think that this is correct? Total cost for parts excl. work is appx 5,500 USD. Could this be correct?
As an non pleasant add on to this, the cylinders needs to be repaired and the pistons replaced as water has leaked in. Could this really happen?
A lot of work must be done on top of this, water and oil pump etc. Total cost including work will be appx 10,000 USD. Does it sound reasonable?
4 questions in one :-) Pls support if possible. I'm desperate for some advice.
BR
Per
BR
Per
Apr 25, 2013 at 11:16 AM
