After replacing brakes driver's side brake will not release
1996 NISSAN QUEST
OSCARZ
  • 4 POSTS
Replaced driver side rotor caliper brake hose and pads. bleed system but brake on that side will not release.
Apr 21, 2013 at 5:29 PM
CADIEMAN
  • 3,544 POSTS
if u remove the caliper and reseat the piston will it turn then?
Apr 21, 2013 at 6:00 PM
OSCARZ
  • 4 POSTS
Yes, but when I apply brakes it locks up again.
Apr 21, 2013 at 6:07 PM
CADIEMAN
  • 3,544 POSTS
are you sure you swapped all the caliper hardware and lubed the slide pin that the caliper mounts to so the caliper can float back and forth properly?
Apr 21, 2013 at 6:35 PM
Good evening,
If you replaced all those item then the issue lies with pressure in the line not being released.
That pressure is most likely from the ABS hydraulic unit. There are valves inside the unit that release pressure when you take your foot off the brake. These valves get clogged up from dirty fluid from the fluid not being changed at the right intervals.
You most likely need to replace the ABS unit.
https://www.2carpros.com/articles/how-to-replace-a-abs-controller
Apr 24, 2020 at 6:19 PM
