When you bled the brakes and opened the rear bleeders while holding the brake pedal down, did it drop at all?
If not then you either have a restriction in the system or possibly a master cylinder issue.
https://www.2carpros.com/articles/how-to-bleed-or-flush-a-car-brake-system
A hard brake pedal could be just a brake booster issue but if we are not getting a pedal drop when bleeding the system then we need to look at the above issue. Let me know and we can go from there. Thanks
Mar 11, 2021 at 1:04 PM
