breaks
1993 DODGE SHADOW
104,000 MILES
DODGESHADOWNIGHTRYDER
Very simple question, Im putting breaks on my dodge for first time and pads dont come with clips on back to connect to caliper is that normal? Other cars I have done alll have clips to slide onto the caliper.
Apr 15, 2013 at 10:08 AM
CARADIODOC
  • 34,306 POSTS
Those are anti-rattle clips and are used mainly on GM products. Some are riveted to the metal backing plates and some clip on to them. Many Chrysler cars had wire anti-rattle springs clipped onto the ends of the pads. You'd be smart to hold a new one and an old pad side-by-side to transfer them, otherwise they can be confusing.
Be sure to run a flat file over the pistons and the fingers that contact the pads to remove any high spots of rust, dirt, or other debris. Those surfaces should be lubricated with a high-temperature brake grease too as well as the caliper mounts.
Apr 15, 2013 at 11:13 AM
