Are you certain there are no leaks? Did you check the pushrod adjustment? See pics 1 and 2 below. Also, when you bleed the brakes, are you starting at the right rear, left rear, right front, and left front order? Are you getting a good stream of fluid?
Let me know. Also, take a look through this link and let me know if it helps:
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
See pics below.
Jan 6, 2023 at 10:57 PM
