brake lights
1999 FORD
62,000 MILES • V10 • AUTOMATIC
GPMANN
I have a class A motor home with the F53 chassis and the brake lights do not come on when the brake pedal is pushed. The brake lights do however come on when i push the trailer brake button. changed the brake switch and bulbs and nothing.
Jun 28, 2017 at 9:10 AM
HMAC300
  • 48,601 POSTS
check the light green wire from brake switch to see if power is there or not. if you have a high mounted stop light and that works then go to t/s switch and check the wires marked for power going in and out of switch if power there then you have a short in wiring leading to stop lights or a bad ground in back where stoplights ground which should be on frame.
Jun 28, 2017 at 9:47 AM
