I recently got this truck, looking at the trailer light connections were a eye sore. Obviously who ever hooked them up didn't have a clue what they were doing. So I cut the plugs off along with the switch under my steering wheel. On the way home one night a guy yells at me and tells me only my third break light is working. So when I get home I get my meter and head under the truck to find a four white harness for the light I disconnect and press the breaks to check for power. Nothing on any of the four. I peel the plastic back that was covering the wires to find a white wire tucked up in there. So I test it and come to find out it's the wire that gets power when I apply the break. I sliced it into my turn signals and thought everything would be good. Now the problem is if I have my turn signal on and hit the breaks it makes a buzzing noise in the cab so I know somethings not right. I've been going around with this for months. Someone please say you have had the same problem and help me with the fix!!
Feb 25, 2016 at 8:50 AM
