Brand new A/C system not working
2005 BMW 325I
89,000 MILES • 6 CYL • 2WD • AUTOMATIC
DANNY EREMIAN
  • 8 POSTS
i have installed brand new A/C system, new aux fan, radiator, compressor ans expansion valve. A/C works great but it doesn't come on right away then after several minutes of driving it comes on.
Some sensor?
Mar 17, 2019 at 11:55 AM
Can you say if the air blowing through the vents is not working or the air is blowing but not cold?
Here is a guide that will help us get started:
https://www.2carpros.com/articles/car-air-conditioner-not-working-or-is-weak
Mar 18, 2019 at 2:26 PM
DANNY EREMIAN
  • 8 POSTS
Hi, and thanks for responding.
Like i said in my question originally, A/C system is brand new, compressor, aux fan, radiator and expansion valve. When the A/C finally kicks on (aux fan and compressor clutch) the system works perfect, ice cold A/C. there is some delay for that to happen and i cannot figure out. yesterday i had Freon tested by a certified mechanic, he does not know the answer to my problem. i am thinking some kind of sensor, i think there is an aux fan sensor?
2005 BMW 325i
Thanks, Danny
Mar 18, 2019 at 10:28 PM
It sounds like the HVAC controller is not working correctly. but to be sure let's check the output signal using this guide and the air conditioner wiring diagrams below:
Mar 19, 2019 at 10:43 AM
DANNY EREMIAN
  • 8 POSTS
been awhile since we communicated.
i have done a whole lot of trial and error with this situation , changing, coolant sensor, ambient temperature sensor, aux fan relay, compressor relays and to no avail, until i had my friend put on ac computer and the code that came up was solar sensor, i did loads of research and couldn't find much information because apparently these do not go bad very often. i even had BMW try and diagnose, and they couldn't figure it out.
finally i found the location in the front window down in the dash.
i hooked it pulled it out and exposed it and i started to get more response from system.
changing this thing is to pull out complete dash and cluster which i can't afford so i am buying a new one and splicing to old wiring , should work.
but that was the whole problem,
thanks for your help figured you would be interested in final conclusion.
Danny
Jun 11, 2019 at 1:53 PM
Glad you could get it fixed, that kind of problem can be tough. Please use 2CarPros anytime we are here to help.
Jun 12, 2019 at 11:40 AM
