when I stop I can feel the brake pedal fade down? Scary
2007 GMC SIERRA
43,000 MILES
SIERRA68
Replaced both front rotors and pads and still did not help! Now when I stop I can feel the brake pedal fade down? Scary.... can you help me please?
Apr 13, 2013 at 5:14 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Here is the information you requested. Here are a few tutorials for you to view on how to replace a brake master cylinder and how to bleed the system after the repair has been made:
https://www.2carpros.com/articles/how-to-replace-a-brake-master-cylinder
https://www.2carpros.com/articles/how-to-bleed-or-flush-a-car-brake-system
Since you are installing a new brake master cylinder it would be best to bench bleed the unit before installation to remove air from the new unit prior to installation on the vehicle. Here is a YouTube tutorial from our site showing how to do so.
https://youtu.be/WDxvEQrMkBg
I've attached picture steps below on how to replace the brake master cylinder and bleed the system on your truck. Hope this helps and thanks for using 2CarPros.
Mar 31, 2021 at 10:34 PM
