Braking pedal pumps when applied
1996 JEEP GRAND CHEROKEE
170,000 MILES • 5.0L • V8 • 4WD • AUTOMATIC
LZLAMB
  • 4 POSTS
When i press on the brake pedal when slowing down from highway speed the brakes pump and the vehicle shudders. I've replaced the rotors and pads in the rear and just the pads in the front.
Aug 16, 2020 at 3:11 PM
When this happens do you feel the vibration in the steering wheel? If so, the front rotors are most likely warped and require replacing or turning if you have enough rotor left.
Since you replaced all the other components you have replaced, I would just go ahead and replace the front rotors as well.
Let me know if you have questions and we can go from there. Thanks
Aug 16, 2020 at 5:44 PM
LZLAMB
  • 4 POSTS
Yes, there is a slight steering wheel vibration. Thanks for the advice, I've got rotors on order.
Aug 17, 2020 at 7:55 AM
Sounds great. Let us know how you make out as I am confident that will take care of this for you. Thanks for the update.
Aug 17, 2020 at 8:50 AM
LZLAMB
  • 4 POSTS
Thanks for your advice. Changed front rotors vehicle stops smooth again. Thanks
Aug 20, 2020 at 4:33 PM
Awesome. Thanks for the update. Glad you are all fixed up. Please come back to 2CarPros next time. Thanks again.
Aug 20, 2020 at 6:01 PM
