When you press the brakes there is a slight pull to the right?
2013 BMW X1
93,000 MILES • 4 CYL • TURBO • 4WD • AUTOMATIC
BHAMDOC1973
  • 2,008 POSTS
I bought this car with minor rust on it and it has been parked for a while. All rotors have rust on them and when you press the brakes there is a slight pull similar to when a lower control arm is bad. Changed front brakes/rotors on both front and lower control arm on one side. The noise from rotors is way less but the car goes to the right when I push the brakes. I greased all the pins in front. Can the rear cause such a pull?
Oct 4, 2022 at 11:38 AM
Not really, I would rotate the tires front to back and then take it for a test drive, let me know. If that does fix it look for lower ball joints and control arm bushings.
Here is a guide to help you:
https://www.2carpros.com/articles/popping-noise
Check out the images (below). Let us know what happens and please upload pictures or videos of the problem.
Oct 4, 2022 at 12:33 PM
BHAMDOC1973
  • 2,008 POSTS
Couldn't confirm the other side was bad until i put it on the lift, no wonder why. When i checked it on the floor it looked good, lol.
Oct 5, 2022 at 2:21 PM
BHAMDOC1973
  • 2,008 POSTS
I removed the two bolts holding the lower control arm from wheel and other end, but the thing is super stuck to the ball joint. I sprayed it with rust blaster and hammered it and nothing. Too tight to put any type of puller on it.
Oct 5, 2022 at 2:22 PM
Yep, sometimes you need to put it up on the rack to see better. Upload videos if you have any troubles.
Oct 5, 2022 at 5:25 PM
