Whenever I came to a stop the van brakes okay when I pressed the brake, but after a little bit the pedal start going down like is loosing pressure and the van moved forwards until I pressed a little more for a few more times until the pedal is all the way down and the van will not move forward anymore. It will not happen every time I brake but enough to cause me concern. This all started when a friend of mine helping me changing the whole front end broke off the cable for the ABS speed sensor of the passenger side and the brake, ABS and TCS light came on which brings me to my other problem. I replaced the speed sensor and wiring and brake light came off but the TCS and ABS light are still on and the brake is showing off from time to time.
Jan 31, 2018 at 11:43 AM
