Brakes are not releasing after removing my foot from the pedal. Repair shop diagnosed as bad front calipers.. I changed calipers, pads and rotors but the issue persists. I replicated the issue with the front tires elevated. The wheels clearly lock-up after applying the brakes then would eventually release and rotate by hand.
There is feedback related to possibly being the brake light switch impeding the pedal from returning to it’s proper position, the rod from the pedal to the master cylinder being out of adjustment or petroleum in the brake fluid causing internal gaskets to swell.
None of these suggested root causes makes sense to me as the brake switch mechanism nor the rod have been to touched hence why would they be out of adjustment?? The contamination of the brake fluid with a petroleum product is also questionable as what could be the source of the petroleum product contamination?
Any guidance will be greatly appreciated as all the mainstream repair shops want to do is continue replacing items as their primary method of diagnosing the issue.
Thank you,
MartyK
Thank you,
MartyK
Mar 14, 2020 at 4:12 AM
