We replaced brake booster and master cylinder. Booster did have brake fluid inside of it from leaking master. Bled manually then ABS bleed, then manually again. brake pedal pumps hard when off and when car is on. However, once you try to move even half a rotation of the tire the pedal reverts to being spongy and stays that way until you pump them up again.
Aug 9, 2021 at 4:31 PM
