Brakes pedal goes to the floor
2010 FORD FUSION
150,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
GRAVEL
My brake pads were metal to metal so i replace the rotor and pads. Bled the brakes and had a pedal but it slowly goes to the floor. So, went through the calipers and the rear calipers were bad. Replace them now the brakes will not bleed i have no pedal.
Dec 10, 2021 at 5:33 AM
Good morning,
This sounds like you have a bad master cylinder as that is where the pressure is produced for the system.
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
I attached the procedure for replacing the master cylinder.
https://www.2carpros.com/articles/how-to-replace-a-brake-master-cylinder
https://www.2carpros.com/articles/how-to-bleed-or-flush-a-car-brake-system
Dec 10, 2021 at 7:11 AM
