AS FAR AS 4 LOW, IT'S A TOUGH REALLY GEARED DOWN SPEED, IT IS HARD TO BOG IT DOWN
IN FACT, I TAUGHT MY DAUGHTER HOW TO DRIVE "WILLY", STARTING WHEN SHE WAS 7 YEARS OLD, 100% PROFICIENT AT AGE 10, THIS INCLUDED BASIC TROUBLESHOOTING, HAND CRANKING, CHANGING THE OIL (DOING OTHER MAINTENANCE PROCEDURES)
SHE LEARNED IN 4 LOW, THIS SAVED MY STARTER FROM MEGA CRANKINGS, GETTING PAST "DUMPING THE CLUTCH" AND THE ENGINE DYING IS ALMOST NON-EXISTENT IN 4 LOW, THIS MADE IT EZier AND LESS STRESSFUL ON HER TILL SHE MASTERED EASING THE CLUTCH OUT
PICS OF HER AT 10 (SHE LIKED THE HAND CRANK OVER THE STARTER SO SHE COULD SHOW OUT)
HER BIRTH DATE IS THE HOOD NUMBERS- WHICH MEANS SHE'S GONNA INHERIT HIM! 'SPECIALLY SINCE SHE "HELPED" RESTORE HIM AT AGES 3 AND 4
IT'S YOUR CALL!
I TEND TO "OVER MAINTAIN MY TWO TOO"
IF THE MASTER AND BOOSTER AIN'T LEAKING AND SEEM TO BE OK - I'D PROBABLY LEAVE 'EM ALONE!
YOU GOTTA MAKE FRIENDS WITH SOME "AUTO EXPERIENCED FELLERS" (ONES THAT ACTUALLY "KNOW", NOT "EXPERIMENTERS")
YOU NEEDTA LEARN, EVEN IF YOU PAY THE KNOWLEDGEABLE AUTO PARTS STORE "GENIUS" TO COME TO YOUR HOUSE AFTER HOURS TO SHOW YOU HOW!
.,.,.,.,.AND YOU CAN FIND A FELLER LIKE THIS, IF YOU HAVE A TRADE-ABLE SKILL, IT'S EVEN BETTER TO BARTER!
"YOU TUBE" GIVE YOU SOME HELP - AT LEAST IN HOW THE TOOLS WORK - EVEN IF YOU WATCH ANOTHER CAR'S REAR BRAKES
"ERIC THE CAR GUY" IS VERY INFORMATIVE ON TOOL USAGE AND INSPECTIONS/ CLEANING/ TIPS (LOOK FOR HIS VIDEO ON DRUM BRAKES - IF HE HAS ONE FOR FORDS, EVEN BETTER)
UNTIL YOU ARE SKILLED W/ THIS
ALWAYS ONLY DISASSEMBLE ONE SIDE
TILL YOU GET THE OTHER DONE
- IT WILL BE A "MIRRORED IMAGE" TO GO BY WHEN YOU START SCRATCHING YOUR HEAD
PRIMARY AND SECONDARY SHOE PLACEMENT IS CRITICAL- EVEN ON MINE, DRUMS ALL THE WAY AROUND, THE SHORTER SHOE LINING GOES "FORWARD" OR CLOSEST TO THE FRONT OF THE VEHICLE
THE LONGER SHOE LINING GOES TO THE REAR
THIS APPLIES TO BOTH SIDES AND BOTH AXLES
(NOT 2 SHORT ON ONE SIDE- AND NOT 2 LONG ON THE OTHER SIDE) THIS IS SORTA IMPORTANT!
SEE MY SO VERY SIMPLE BRAKE SYSTEM ON MY '46 WILLYS SHOES IN THE 1st PIC - FRONT OF JEEP IS TO THE RIGHT- NOTICE SHOE LINING LENGTHS
AGAIN IN 2ND PIC- FRONT OF JEEP IS TO THE RIGHT
SORTA WHAT STATE ARE YOU IN? I HAVE SOME POSSIBLE WAYS TO SAVE MEGA BUCKS!
YOUR TURN
THE MEDIC
May 5, 2015 at 5:23 PM
