I have a 1990 Chrysler new Yorker fifth avenue. I made a mistake and put engine oil in the brake fluid. I flushed out the brake lines, cleaned the master cylinder, put it back together and started bleeding the brakes. My front driver side did have brakes but not the passenger. The more I bleed the brakes it seems to be getting worse. no I have no pressure on either side. When I cap off one side of the master cylinder and bleed the brake I get fluid just fine. Once I connect everything together all of a sudden i don't get any fluid from either side. and still no brakes, When I push down the brake pedal when bleeding the brakes it sounds like there is more air sound coming from the pedal? no leaks I have seen yet, when bleeding the brakes the pedal stays squishy, and I can push it all the way to the floor and it seems like it tries to gain pressure but never does. None of the warning dash lights have came on. I do have a scan tool but with it being an older car I am not able to find the spot I would plug it into for it to read the system. Since the contamination I have not replaced any parts, only flushed the lines and cleaned the master cylinder.
what am I doing wrong or missing?
Jul 22, 2025 at 7:46 AM
