my wife was driving and the brakes started locking up?
2017 CHEVROLET SILVERADO
108,000 MILES • 5.3L • V8 • 2WD • AUTOMATIC
GRIZLYMULE
  • 9 POSTS
First off about 2 years ago the truck was hit on the left side just in front of the rear wheel and did clip the rear wheel and the axle was replaced during repairs. (2) I replaced brake pads on the truck a few months ago for the first time and had bought the truck new. I'm not a mechanic but have done brake jobs on every vehicle I've ever owned over 40 years and it's been my experience that the rear brakes, also disc by the way, only need changing about every other time the fronts are changed because most of the braking power is in front but the rear pads were badly worn especially the right rear which was down to metal and even needed a new rotor. I bled the brakes according to specs. Within a day or two, my wife was driving and the brakes started locking up and when she pulled over could smell the brakes and said the right front was smoking. When I looked at it the right front and rear rotors were blackened from getting hot but the left side wasn't maybe slightly. I've spent hours online trying to find the problem and have changed the right front caliper just to try and see if it helped. It did not. I drove it about 20 miles holding up on the brake peddle because my wife says she pumps the peddle from underneath and says it helps and the brakes never locked up so a mechanic friend said replace the booster which I did and that also didn't work so I returned it and put the old one back on. I wonder if the hit to the left rear damaged something like a module. I have visually inspected the lines/cables to all of the wheels and didn't see anything loose or broken. Hoping this doesn't run into $1000's to fix. Warning lights intermittent Check Trailer brake system, Stabilitrac, and Antilock system lights. The Trailer Brake system is the one that lights up the most often dinging a few times then going off sometimes several times then not for a day or two. I have cleaned the connection off on that module because I saw it in a video.
Jan 31, 2021 at 11:13 AM
Good afternoon,
I suspect the brake hose is collapsed in the right front not allowing the pads to release.
https://www.2carpros.com/articles/how-to-bleed-or-flush-a-car-brake-system
Pump up the pedal and jack up the right front. I bet it is tight to turn or almost locked up. Open the bleeder and see if fluid shoots out. If it does, then the wheel will turn and that will confirm the hose is the issue.
Jan 31, 2021 at 1:35 PM
GRIZLYMULE
  • 9 POSTS
I'll try changing hoses on all four to see if that works because I'm having issues with all of them. Thank you, sir and I'll get back to you.
Feb 3, 2021 at 7:23 AM
You are welcome.
Always glad to help.
Feb 3, 2021 at 8:23 AM
  • 7 POSTS
I have to bring the truck to a stop. I pump the brakes and they release. I have changed the booster, the air pump to the booster and the cruise and brake module. It still does it. help
Feb 22, 2021 at 11:35 AM (Merged)
Since it is only the front brakes, I question the master cylinder. Try this. When the brakes are locked up, see if they release if you open the brake line at the master cylinder. If it doesn't, work forward. Move to the caliper. Open the bleeder and see if the brake releases.
I have seen situations where the rubber brake hose on the calipers would fail internally causing the brake pads to remain partially actuated or fully. When driving, there would be enough drag on the brakes to cause them to get hot. Now, brake fluid expands when it is hot, so the brakes would slowly continue to engage.
If the brakes release when you open the bleeder on the caliper, replace the rubber brake hose.
Let me know what you find.
  • 7 POSTS
I would say it's got to be something in the electronics of the master cylinder is working fine. it's releasing but the traction control light keeps coming on. if you turn it sharp right or left or if the brake locks up. it'll flash on and then flash off, so it's got to be something in the ABS. I just don't know.
Welcome back:
I didn't realize turning caused this problem. With that in mind, the first thing I would check are the ABS sensors on the front wheels. Check to confirm the wiring isn't damaged, shorted, or not properly plugged in at the connector.
I attached pictures of where the wiring mounts and sensor location. Check both sides. Also, based on the year, I strongly recommend scanning the computer for diagnostic trouble codes.
  • 7 POSTS
Turning never caused this problem, it just started when I turn it it acts like it's shaking.
Are you sure the brakes aren't hanging up a bit all the time?
  • 7 POSTS
Yes..
Welcome back:
I forwarded this to the owner for his ideas or suggestions. Expect a response from Ken. I will continue watching what is happening and try to help.
There are a couple things that come to mind first is the push rod that from the booster needs to be adjusted inward, when the brake are locked loosen the master cylinder mounting bolts if the brakes start rolling you know the push rod is the problem next we should run the codes becasue it sounds like the ABS/traction control module is going out. Lets run the codes to confirm the issue
https://youtu.be/rTtAnsOlZU4
If the module is to blame this video with show you how to replace it with instruction and diagram below to help show you on your truck.
https://youtu.be/lUotkKXG9dY
ABS traction control module replacement reprogramming.
Note:
DO NOT program a control module unless directed to by a service procedure or a service bulletin. If the control module is not properly configured with the correct calibration software, the control module will not control all of the vehicle features properly.
Ensure the programming tool is equipped with the latest software and is securely connected to the data link connector. If there is an interruption during programming, programming failure or control module damage may occur.
Stable battery voltage is critical during programming. Any fluctuation, spiking, over voltage or loss of voltage will interrupt programming. When required install the EL-49642 - SPS Programming Support Tool to maintain system voltage. If not available, connect a fully charged 12?V jumper or booster pack disconnected from the AC voltage supply. DO NOT connect a battery charger.
Turn OFF or disable systems that may put a load on the vehicles battery such as; interior lights, exterior lights (including daytime running lights), HVAC, radio, etc.
During the programming procedure, follow the SPS prompts for the correct ignition switch position.
Clear DTCs after programming is complete. Clearing powertrain DTCs will set the Inspection-Maintenance (I-M) system status indicators to NO.
Reference Information
Special Tools
Replace and Program Control Module or Reprogram Control Module
To program a replacement or an existing control module, perform the following procedure:
Install EL-49642 - SPS Programming Support Tool .
Access the Service Programming System (SPS) and follow the on-screen instructions.
On the SPS Supported Controllers screen, select K17?Electronic Brake Control Module - Programming and follow the on-screen instructions.
On the SPS Supported Controllers screen, select K17?Electronic Brake Control Module - Configuration and Setup while following the on-screen instructions.
At the end of programming, choose the “Clear All DTCs” function on the SPS screen.
Unsuccessful Programming Recovery
In the event of an interrupted or unsuccessful programming event, perform the following steps:
Ignition ON. Ensure the control module, DLC and programming tool connections are secure and the SPS software is up to date.
Verify the control module can be reprogrammed.
If the control module cannot be reprogrammed
Ignition OFF for one minute, ignition ON.
If the control module cannot be reprogrammed, replace the control module.
If the control module can be reprogrammed.
All OK.
All OK.
Repair Instructions
Perform the Diagnostic Repair Verification after completing the repair.
Control Module References for Control Module replacement, programming and setup
Like JACOBANDNICKOLAS said it could be a bearing hub going out causing the wheel speed sensor to have a false reading.
https://youtu.be/ZgiPRG6jffc
  • 7 POSTS
Found the problem and it was not showing up on the scanner. We've changed the brake booster the air component that went to the booster the brake lines the master cylinder. Could not find anything wrong it was not showing on the scanner the codes weren't there we were changing these parts one at a time and it was still doing the same issues. The first thing we changed was the booster then it showed up it wasn't getting enough air to the booster so we change that component then we change the brake lines then we changed the master cylinder. We were perplexed and could not find the issue we had two other mechanics looking at it. One of them and told us that sometimes the boosters can be bad even though it was from GM and come right out of the box we went back to that we changed and put a new booster on that was the problem. Thank you for everyone helping with this. We just found the problem yesterday we've been two weeks working on this.
Happy to help. What was the actual problem? I'm sure it will help someone in the future.
  • 7 POSTS
We change the brake booster, the pump, the brake lines, and the master cylinder. The new brake booster we put in from GM was bad.
Wow! You buy the best and this happens. However, I guess it can happen.
Regardless, I'm glad it's fixed. Take care and let us know if you have questions in the future.
  • 7 POSTS
Thank you and everyone else.
MIKALYNN BURKE
I was driving down the road was coming up to a stop sign and my truck did not want to stop, so for me to stop I had to press hard on the brakes. Now it seems my brakes are sort of locked up. My brake pedal is stiff and hard and I have to press hard on the pedal to stop the truck and when I do it makes like a grinding sounds. I have took out my ABS fuse to see it that was the problem, nope still doing it I have no idea what is going on with it. It acts like it is slowing it self down. Please someone help me.
HMAC300
  • 48,601 POSTS
It sounds like there may be an ABS problem where it is done this and even removing fuse will not cure it. this will have to be scanned for codes. Check out this video
it cold be hydraulic as well but I kind of doubt it from your description.
Happy to help. And I can't believe I missed your identifying the problem in your prior post. Sorry about that.
To me it sounds like you have a problem with the rear brake shoes, like one of them has come apart and it now wedged between the drum.
Please check it out and get back to me. Also, you could have a problem with the brake booster leaking vacuum this would be the reason for the hard pedal.
Best, Ken
KATIE CARNCROSS
  • 4 POSTS
Stopped and the driver side wheel are extremely hot . Looks like brake pads but could it be caliper too?
Feb 22, 2021 at 11:36 AM (Merged)
Yes it sounds like you have a caliper slide that is frozen which is common. Here is a guide to help you get the problem fixed and the pads changed. Check the video at the top of the guide.
Please let us know what happens, we are interested too see what it is.
KATIE CARNCROSS
  • 4 POSTS
We changed the brakes. Which seems to help with the wheel getting so hot it did crack the brakes that was on truck to begin with. How ever when doing them found white residue over edge of rotor still unsure what that was though did somewhat remove with brake cleaner and rag.
KATIE CARNCROSS
  • 4 POSTS
Windows phone. Brakes ended up doing the same last night so changed out rotors and caliber today.
KATIE CARNCROSS
  • 4 POSTS
Will do
CHARLESPARKS832
Drivers front brake locked up and was smoking. so I changed the caliper, everything was okay for the forty mile trip home. The next day I drove five to eight miles when both front brakes locked up smoking. They released after two hours. How should I trouble shoot this problem?
SCGRANTURISMO
  • 4,897 POSTS
Are there any Direct Trouble Codes (DTC)(s) set or is your vehicle's ABS light illuminated?
Thanks,
Alex
2CarPros
CHARLESPARKS832
Alex, the ABS light sometimes comes on, and DTC code appears. But it resets itself. I don't know if this is connected, but sometimes the doors; unlocks and locks! The alarm chime, also sounds when this happens. I've checked the fuses they are okay. Also service tire monitor system sometimes appears. I don't know if this is relative to my problem.
SCGRANTURISMO
  • 4,897 POSTS
Okay, this could be a problem with ground #300, which is located below the drivers door on the body mount. Check and make sure that the ground is clean, corrosion free, tight, and making good metal to metal contact. Please check this ground out and get back to us with what you are able to find out.
Thanks,
Alex
2CarPros
CHARLESPARKS832
Is that care of the brake issue? I took it for a short five miles, and it didn't lock up but both front started to heat up had to stop for a while.
SCGRANTURISMO
  • 4,897 POSTS
Hello again,
This is the ground for your vehicle's Electronic Brake Control Module (EBCM). 75% of all electrical problems on a vehicle are ground problems.If the ground is okay, I would suspect the EBCM itself. In the diagrams below I have included the directions for removal and installation of the EBCM. Please go through the guide and get back to us with what you are able to find out.
Thanks,
Alex
2CarPros
