It could be as simple as a "unknown" twist in the rubber brake hose to it. I've had buddies helping me and added that sweet little twist in there after letting the caliper dangle around!
Or the hose itself has internal oldness or breakdown, I've seen this many many times! The hose starts acting like a check valve letting fluid force on through, when you release the pedal the fluid cannot back back out.
If the brake remains locked up, you can verify it is a faulty hose by simply opening up the bleeder valve on that brake. If the brake releases immediately, it is the hose!
We have many repair guides (top right of our pages) Here's one of them I'm linking you to:
https://www.2carpros.com/articles/brake-caliper-replacement
Return with good news.
The Medic
Jun 16, 2019 at 8:05 PM
