Bought it with a soft brake pedal. Vacuum holds when pumping brakes, replaced master cylinder and bled brakes, got better, but after reading on it turned out these have mushy pedal. VSC off light sometimes comes on when i start it, once i drive off, it goes away. Also, this has a button to change from 2 to 4wd, when in 4wd is it supposed to be this hard to move the car on a driveway when in 4wd mode and wheel turned? I scanned it and got these codes. I replaced the battery as it kept on dying, not sure of codes were from before or after battery replacement.
Jan 3, 2025 at 10:07 AM
