Brake pedal goes to the floor?
1997 TOYOTA CAMRY
100,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
PACIFICISLANDER
  • 240 POSTS
Does this have something to do with the ABS other than the booster and master cylinder? It catches a little then sinks to the floor.
Master cylinder level remains the same, no fluid out of the bleeder valve as we bled.
Oct 10, 2022 at 4:43 PM
If this happened before anything was opened, then suspect the master cylinder has failed. Do me a favor and take a look through this link:
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
If you look below, I attached the directions for the removal and replacement of the brake master cylinder. Additionally, here is a link that you may find helpful:
https://www.2carpros.com/articles/brake-caliper-replacement
See pics below.
Oct 10, 2022 at 8:41 PM
PACIFICISLANDER
  • 240 POSTS
Thank you very much. You're still the one as usual.
Oct 11, 2022 at 11:27 PM
I'm so sorry!!! I didn't realize it was you. You are very welcome, and I hope all is well.
Let me know if this takes care of the issue and if I can help in any way. Take care of yourself, my friend.
Oct 12, 2022 at 5:25 PM
