Brakes drift to the floor
1997 GMC SONOMA
127,000 MILES • 4.3L • 6 CYL • 4WD • AUTOMATIC
MADLENEPGH
Brakes have been drifting to the floor for the last three weeks or so. When I am at a stop sign I feel like the truck is drifting so I have to apply the brakes even more and they are going down toward the floor. Over a three week period the fluid level was maintained, lines underneath were all checked and no leak found, and master cylinder was suspect and replaced with a new master cylinder. But the brake pedal still drifts to the floor. What do you think?
Oct 19, 2017 at 6:07 PM
STEVE W.
  • 15,113 POSTS
Brake pedal drop only happens with a fluid leak, either external though a bad line/wheel cylinder or caliper seal, or internal through a bad master cylinder or fluid bypass into the booster through the master cylinder.
If you are not losing fluid but the pedal is still dropping you either have a second bad master cylinder or possibly a bad rubber line that is acting like a balloon.
Air in the system would create a mushy pedal.
Oct 19, 2017 at 8:18 PM
