Hi, I got gas Friday and when I was starting to drive someone almost backed into me. I hit the brakes and it sounded like someone hit me. I had no damage or any cars around me. Not sure what this could be. The other problem is when I hit the gas the rear end feels like it is trying to catch up like it is almost lagging. I checked the u joints there was no play in it. Any ideas? Also, sometimes when I hit the gas the truck will only go up to 2000 or 2500 rpm and will not go go faster. I have my foot to the floor. I have new fuel pump new tank new filter and a new throttle body. Ever since I put the new throttle body on it does not act right. When I start it up it runs rough. I also changed distributor cap wires and plugs and rotor. Also the electronic thing under the distributor cap. The brake fluid is full no leaks master cylinder and brake booster look good. Thanks.
Feb 11, 2018 at 12:00 AM
