okay first question my passenger rear tire is skipping or dragging when making a right turn at a very low speed. I put the rear axle up it was a little loose so I ended up replacing the seal .and the bearing cuz the differential look good.. took it for a test drive but still having still doing the same thing. I check all the brake lines nothing leaking. I plugged in my ob2 reader. I got 3 codes. it telling me all 3 wheel speed sensors are bad. so I replaced all there sensors. can any help e I'm
Mar 1, 2026 at 10:02 AM
