After replacing the Master Cylinder there is no fluid coming out of the brake lines?
2003 CHRYSLER PT CRUISER
100,000 MILES • TURBO • 2WD • AUTOMATIC
MICHAELMAXWELL459
  • 16 POSTS
Brakes do I bleed or anything? We replaced the master cylinder, and now we don't have any fluid coming out of the lines at all.
Sep 12, 2022 at 7:52 PM
Was the new Master Cylinder bench bled prior to installing it? When bleeding the brakes, are you starting at the right rear, to the left rear, to the right front, and ending at the left front?
Do this. Make sure the Master Cylinder is full and remove the cap. Open the brake bleeder at the right rear wheel and allow it to remain open to see if it will gravity feed. If it does, close it, recheck the Master Cylinder fluid level, and do the same to the right rear, and so on.
If that works, then you can bleed the brakes with a helper.
As far as the bleeding procedures are concerned, read through step 3 in this link:
https://www.2carpros.com/articles/how-to-replace-a-brake-master-cylinder
Here is a link that explains how to bleed the system once the new Master Cylinder is installed:
https://www.2carpros.com/articles/how-to-bleed-or-flush-a-car-brake-system
Sep 12, 2022 at 8:48 PM
MICHAELMAXWELL459
  • 16 POSTS
Okay, yes, we tried that, and it didn't work. but now what we did was pull off all the brake lines from the calipers and I think we got stuff messed up. So, is there anything you might be able to tell me like as if I was starting from having everything brand new and no fluid in it whatsoever and I think you should it has an ABS system as well.
Sep 12, 2022 at 10:06 PM
If you had the ABS apart, then it needs to be bled as well. This procedure requires a scan tool that can communicate with the antilock brake module.
If you look below, I attached the directions for the procedure.
See pics below.
Sep 13, 2022 at 12:45 PM
