Pedal goes to floor. Notice fluid coming from driver side rear brake.
Sep 9, 2019 at 1:25 PM
DANNY L
CERTIFIED EXPERT
Hello, I'm Danny.
Losing brake fluid from what you've mentioned is an obvious leak in the system. You will need to remove the tire to see if a brake line or the brake caliper is loose/broken/defective. I would suggest having it repaired as soon as possible. Your truck should not be driven until repaired for fear of losing brakes entirely. Here is a tutorial to view to get you started on what to look for:
