Brake pedal goes to the floor when first started
2000 DODGE STRATUS
70 MILES • 4 CYL • AUTOMATIC
JOYCE KORUS
History: Eight months ago had pedal go quickly and easily to floor after just starting up. never while driving. About three or four times it occurred.I was told that the fluid was low by Napa and my mechanic replaced some lines. But it happened twice even after he did! Last six months, all is fine! Last evening, drove and all was fine. Today, started her up, red brake light on and brake pedal goes easily to floor. tried to pump it, but no luck. Checked fluid, looked fine, not low at all. I am totally confused! Bought this car from an elderly couple where it sat in a garage for many years. Could you give me some idea as to what's going on?
Nov 1, 2019 at 1:46 PM
MASTERWRENCH
  • 258 POSTS
Take a look at the article below. It does a very thorough job explaining what may be causing your issue. If your fluid is full though, it's most likely a leak somewhere or a bad master cylinder.
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
Let us know what you find!
Nov 3, 2019 at 10:51 AM
How many miles are on the car? It does sounds like a bad brake master. This guide can walk you through how you replace it:
https://www.2carpros.com/articles/how-to-replace-a-brake-master-cylinder
Nov 8, 2019 at 2:38 PM
Can we ask what the problem was please?
Nov 11, 2019 at 5:48 PM
