Left front side brake pad is really tight
2012 SEAT IBIZA
87,000 MILES • 1.6L • 4 CYL • TURBO • 2WD • MANUAL
NICOLLE92
I was wondering why my left front side brake pad is really tight and my right front side brake pad fits perfectly. what could be the problem?
Aug 23, 2019 at 10:40 AM
Welcome to 2CarPros.
If you are referring to how the pad fits into the mount, remove the aluminum hardware and clean rust from the mount. It builds up there and causes the hardware to squeeze the pad where it mounts. The pads should be free floating, so you should be able to move them when they are mounted (until you hit the brake). Often times, I will take a small file and clean rust and dirt from the area where the pad sits.
Let me know if that helps or if I misunderstood.
Aug 23, 2019 at 12:03 PM
