Rear wheel leaking fluid
1989 FORD RANGER
100,000 MILES • 4 CYL • 2WD • MANUAL
CHARLES CARD
rear wheel leaking fluid how can I fix it
May 1, 2018 at 11:15 AM
Good afternoon.
Check the brake line at the wheel. if that is okay, then remove the wheel and drum and inspect the wheel cylinder. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Apr 14, 2021 at 10:11 AM
