It sounds like either you have air in the master cylinder or the rear plunger has failed. It could also be a plugged proportioning valve.
If you have someone step on the brake and crack the rear line lose on the master what kind of flow do you have there? Note do not let the brake pedal up until you re-tighten the line or you will let air into the master.
Rich
Mar 11, 2020 at 11:37 AM
