Can I drive with ABS disabled?
2013 FORD C-MAX
104,000 MILES
AB7758
ABS module can’t be fixed.
Jun 28, 2023 at 9:54 AM
MATHGEN
  • 128 POSTS
Yes, the base brake system will still function normally. However, under hard braking conditions, the wheels could lock up. Just a precaution, if the red brake warning light comes on, it could indicate a failure in the base brake system, and you should isolate that fault as soon as possible.
Jun 28, 2023 at 10:10 AM
