Calipers are on correctly but now I have no brakes?
2015 CHRYSLER 200
130,000 MILES • 0.6L • 4 CYL • 2WD • AUTOMATIC
MATTBUCHANAN698
I changed my rear brakes but had to bleed the lines for the first time ever. I refilled the fluid with dot 3 and got the air out of the lines. Brake lines are not twisted. Calipers are on correctly but now I have no brakes.
Sep 24, 2024 at 7:21 AM
Chances are if you got air in the system the ABS valves need to be opened using a scanner. Also, the rear brake pads have a timer on the inboard pad that needs to be in the right position in the caliper piston.
Here is a video to show how to bleed the brakes using a scanner:
https://youtu.be/nQRnKyVyMuQ?si=SKp8IPAjG2oz-CMU
Here is a guide to help you see if you have other issues:
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
Please upload pictures or videos in your response of any problems so we can see what to help you with.
Sep 24, 2024 at 3:44 PM
