Brakes
2004 MITSUBISHI SHOGUN
160,000 MILES • 3.2L • 4 CYL • 4WD
KEV ROBERTS
Had new brake pipes but after bleeding the pedal does not get firm.
Apr 6, 2018 at 3:28 PM
CARADIODOC
  • 34,306 POSTS
There are a lot of variables we do not know. Most importantly, was the reservoir allowed to run empty and does the vehicle have anti-lock brakes? If it has ABS and the reservoir ran empty, there is likely to be air in the hydraulic controller. On most vehicles that can only be bled out with a scanner to command the computer to open two valves so those chambers can be bled. That has to be done with two bleeder screws open so the air can flow to them.
If bleeding was done with a helper and they pushed the brake pedal all the way to the floor, it is possible the master cylinder was damaged. Typically that results in a slowly-sinking pedal, and that often does not show up until two or three days later.
Apr 6, 2018 at 5:22 PM
KEV ROBERTS
Yes, I think so because the ABS light came on brake failed light came on and a warning sound.
Apr 6, 2018 at 9:59 PM
This sounds like the master cylinder is damaged and needs to be replaced. Here is a guide to help you see what you are in for when doing the job:
https://www.2carpros.com/articles/how-to-replace-a-brake-master-cylinder
Please let us know what you find.
Apr 9, 2018 at 1:16 PM
