XL Denali auto AWD. Does not build pressure at all. I replaced front calipers, rotors, and pads. Rear calipers and also the master cylinder. Bled the brakes and had some pressure for a couple days but not good at all. Was told to bleed the ABS module. I did that with the truck on blocks and braking to engage the module. After that bled the brakes again. Then something very strange happened. With the wheels off and truck running put it in gear the rear brakes would do their job. The front not only did not work but when I would step on the brake my drivers side front would accelerate quite rapidly. At a total loss as to what is going on there.
Dec 5, 2018 at 3:04 PM
