Brake replacement
2015 MERCEDES BENZ GLA250
56,000 MILES • 4 CYL • TURBO • 2WD • AUTOMATIC
If your brake pads need to be replaced (1mm) do you have to also replace the rotor and sensors on this model or is that just a good recommendation?
Aug 16, 2019 at 9:39 AM
BMDOUBLE
  • 1,139 POSTS
Mercedes has a technical service bulletin that is recommending replacement of the rotors and pads for excessive rust and corrosion. If there is a visible line where the pads sit on the rotors or if the rotors have excessive rust, corrosion, or grooves, replace them. As far as the sensors, I always replace them because they are cheap and the tabs usually crumble from the heat of the braking system but you can inspect before you replace them.
Aug 16, 2019 at 12:42 PM
