Brakes, after replacing everything from the disc to the brake booster the brakes still are not working properly
1998 CHEVROLET 3500
200,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
WHYNOTME926
  • 10 POSTS
Have the truck listed above Dually. Replaced everything from the disc, drum, brakes, brake lines, master cylinder, and brakes booster, and still no brakes. It will work for half a day and then goes out. What can be the cause of this?
Dec 11, 2021 at 4:13 AM
SQM
  • 6,383 POSTS
Are you losing any fluid?
One of the reasons you will have pedal going to the floor if there is a leak. And of course, for having air in the brake lines.
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
Did you have the same issue before replacing of those components?
Another possibility it has a faulty electronic brake control module (EBCM).
https://www.2carpros.com/articles/how-to-replace-a-abs-controller
Let me know little more details of what you have been experiencing.
I have attached the brake bleeding procedure as well as the EBCM diagrams for your reference.
Thank you.
Dec 11, 2021 at 9:01 PM
WHYNOTME926
  • 10 POSTS
Yes, the problem existed before replacing all of these things. I Have tried to bleed them several times and no visible leaks that i know can be seen. The ABS has been removed could that be the cause of them not working?
Jan 5, 2022 at 8:45 PM
WHYNOTME926
  • 10 POSTS
Also going to try to look at the EBCM to try and rule that out or hopefully fix the problem.
Jan 5, 2022 at 9:00 PM
SQM
  • 6,383 POSTS
When you say ABS has been removed, what exactly was removed?
A faulty EBCM will keep the brakes from working properly.
Let me know what you find.
Jan 5, 2022 at 10:18 PM
WHYNOTME926
  • 10 POSTS
I have removed the whole ABS system. It is directly hooked up to the master cylinder. When I bought the truck the person that had it before took out the entire brake system trying to create their own brake system. I'm just trying to make it make it plain Jane brakes. Master cylinder 2 brake lines to the brakes.
Jan 7, 2022 at 10:05 AM
SQM
  • 6,383 POSTS
It's interesting that they did that. Let me know if you are able to rule out the EBCM.
Jan 7, 2022 at 1:11 PM
WHYNOTME926
  • 10 POSTS
You have to put in a longer pin between the booster and the master cylinder but for now it is working. So, we will see for how long and hope for the problem to be solved.
Jan 7, 2022 at 5:26 PM
SQM
  • 6,383 POSTS
It's good that you have it functional. Let me know how it goes.
Jan 7, 2022 at 8:54 PM
