The dash brake light is on, and has been for the past 5,000 miles. At 172,000 miles, I performed a rear brake overhaul, and at approximately 163,000 miles, a shop down the road performed a front brake overhaul. The rear axle had a brake fluid flush recently, but the front axle never had a brake fluid flush. I have checked the master cylinder on a regular basis, and I am not losing any fluid, nor are there any leaks around the bleeder valves on each caliper. Do you have any suggestions on what to do next? Thanks!
Jul 30, 2016 at 8:48 PM
