Brakes feel like they are not catching barely stopping the van
2006 DODGE CARAVAN
189,000 MILES • 6 CYL • 2WD • AUTOMATIC
BUBBASTUMP
Brake pedal was going to floor after I drive a few miles. Checked for leakes, none. Bleed brakes and still going to floor. I bench bleed master cylinder install new. Bleed brakes again. Now pedal is tight, but feels like brakes are not catching when I drive. I mean barely making van stop. Please help
Jan 21, 2017 at 12:28 PM
HMAC300
  • 48,601 POSTS
you probably have air in the ABS unit. this happens a lot with diy. you need to go to a mechanic with a scanner able to open all valves on the ABS so air can be bled.
Jan 21, 2017 at 12:30 PM
BUBBASTUMP
I was bleeding from rear to front when I got to front passenger. Pedal got really lose and air came out. Pedal than had no resistance. We continued bleeding process and air continued to come out. After a few times pedal became hard again. Still feels like brakes are not grabbing. Is the wheel cylinder bad?
Jan 21, 2017 at 2:21 PM
HMAC300
  • 48,601 POSTS
it still can be an ABS problem not letting fluid go to that wheel. try a power bleeder if still not working have a mechanic look at it.
Jan 21, 2017 at 3:35 PM
BUBBASTUMP
I am poor. Going to mechanic not an option. Could the brake booster be the problem? I was going to to a few test to see if booster is good. Do you have any tips on checking it? Also, it was front passenger that the pedal lost resistance.
Jan 21, 2017 at 9:59 PM
HMAC300
  • 48,601 POSTS
because it is one wheel it is not a booster it is more than likely the ABS. so try the power bleeder see if that is okay. otherwise a mechanic needs to look at it you cannot drive it like that.
Jan 22, 2017 at 8:12 AM
HMAC300
  • 48,601 POSTS
Also, check brake hoses if a front wheel if bad replace both.
