Based on your description, either there is an issue under the dash where the pushrod attached to the pedal assembly or the master cylinder is bad.
This vehicle may have a Teves brake system. They are unique and not seen too often anymore. So just to confirm, the brake pedal travels to the floor. Is that correct? Also, does your brake master cylinder under the hood have the components mounted to it that I have circled in the picture below?
See pic below.
Oct 20, 2024 at 7:45 PM
